making my own pickguard http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=8912 |
Author: | Louis Freilicher [ Wed Oct 18, 2006 2:28 pm ] |
Post subject: | |
Well I've been looking around for some pickgurad material for an old Gibson A-Jr. mandolin and I could not find anything I liked. So I made a little mold and mixed up some West Systems epoxy in dark red brown and amber to make my own blank. The finished blank is about .1 thick and has the color and look I was wanting. The first shot is the epoxy in the aluminum foil covered mold. The next day I ran the blank through my thickness sander to true up the surfaces, then much wet sanding and buffing. Enjoy! ![]() ![]() ![]() |
Author: | Kim [ Wed Oct 18, 2006 10:41 pm ] |
Post subject: | |
Very clever Louis, I like the tortoise affect you achieved , very interesting. Cheers Kim |
Author: | Arnt Rian [ Thu Oct 19, 2006 8:51 am ] |
Post subject: | |
Interesting! Can we get a better picture, it is a little hard to tell exactly how it looks. Have you started shaping the pickguard yet? Is so, was it easy to cut, shape and polish and so on? How stable does it seem? This is how "Tot-Tis" is made too, no? |
Author: | Dave Anderson [ Thu Oct 19, 2006 8:58 am ] |
Post subject: | |
That looks pretty good but is kind of hard to see. I like the color. |
Author: | Louis Freilicher [ Thu Oct 19, 2006 10:34 am ] |
Post subject: | |
This thing is pretty hard to photograph but here's a few more. So far the material seems to work and polish well. I cut the shape on the band saw (with a zero clearance insert) with no chipping or cracking. I sanded and polished it the same way I would a lacquer finish. The material (after 72 hours) is firm but a bit flexible, defiantly not brittle Louis ![]() ![]() |
Author: | Tom Morici [ Thu Oct 19, 2006 12:18 pm ] |
Post subject: | |
Louis Wow! that looks nice. Great idea, glad you tried that. Don't forget to show us the finished pickguard. Tom |
Author: | Brock Poling [ Thu Oct 19, 2006 12:32 pm ] |
Post subject: | |
How do you get the color in the epoxy, are you using powdered dyes? Liquid? I haven't tried to color the West epoxy... |
Author: | Serge Poirier [ Thu Oct 19, 2006 12:42 pm ] |
Post subject: | |
Great results there Louis, i think i will try that too! ![]() ![]() ![]() ![]() ![]() |
Author: | Louis Freilicher [ Thu Oct 19, 2006 2:29 pm ] |
Post subject: | |
The color is trans tint from stew mac. For this guard I mixed two batched of epoxy. For the dark color I used four pumps of epoxy, four drops of dark walnut, two drops cherry red and two drops of vintage amber. The light color is 2 pumps of epoxy with four drops of vintage amber. I heated up the mold and the epoxy with my grizzly heat gun and poured the dark color first. Then drizzled and swirled in the amber. I tried to keep it heated to the point where I could see air bubbles popping on the surface. Too much heat and the stuff will set up faster and you will wind up with more air bubbles. I'm just about done polishing up the finished guard, so I will post more pics soon. On a side note I'm doing the restoration on this mando in trade for a pearl engraving workshop next Tuesday, so I’ll post something on that when I get back home. Louis |
Author: | Serge Poirier [ Thu Oct 19, 2006 10:05 pm ] |
Post subject: | |
Lookin' forward to that Louis, thanks! |
Author: | Brock Poling [ Thu Oct 19, 2006 11:18 pm ] |
Post subject: | |
[QUOTE=Louis4052] The color is trans tint from stew mac. For this guard I mixed two batched of epoxy. For the dark color I used four pumps of epoxy, four drops of dark walnut, two drops cherry red and two drops of vintage amber. The light color is 2 pumps of epoxy with four drops of vintage amber. I heated up the mold and the epoxy with my grizzly heat gun and poured the dark color first. Then drizzled and swirled in the amber. I tried to keep it heated to the point where I could see air bubbles popping on the surface. Too much heat and the stuff will set up faster and you will wind up with more air bubbles. I'm just about done polishing up the finished guard, so I will post more pics soon. On a side note I'm doing the restoration on this mando in trade for a pearl engraving workshop next Tuesday, so I’ll post something on that when I get back home. Louis [/QUOTE] I am very intrigued by this.... thanks for this post. I am still a little unclear however, how are you getting the bubbles out of it. |
Author: | Kim [ Thu Oct 19, 2006 11:56 pm ] |
Post subject: | |
[QUOTE=Brock Poling] I am very intrigued by this.... thanks for this post. I am still a little unclear however, how are you getting the bubbles out of it. [/QUOTE] Hey Brock if I may jump in here for Louis, I used to make fishing rods of various kinds. The cotton binding which hold the runners in place and decorate the the upper grip of the rod is coated with epoxy for strength and protection. As part of the process, you apply moderate heat with a heat gun to the still liquid epoxy whilst the rod simultaneously spins on a rotisserie to prevent sag. The idea here is that the heat thins the epoxy making it less viscous. This then allows the epoxy to sink deeply into the cotton bindings and assist in the expulsion of air bubbles from the liquid. The big secret here is to mix the epoxy very slowly trying to keep the air entering the mix to a minimum. Whilst this system works very well it pays to keep in mind, as Louis has already suggested, that the heat also accelerates the setup time of the epoxy and, as I understand, also deteriorates the overall strength of the mix. In this application however, and likewise the pick guards I guess, strength is not really an issue. It is very interesting and clever how Louis has used aluminium foil as a backing in the mold. This assist the reflection of light back through the epoxy adding so much to the colour, I really like what he has done here. Well Done Louis ![]() ![]() ![]() Cheers Kim |
Author: | Louis Freilicher [ Fri Oct 20, 2006 5:24 pm ] |
Post subject: | |
Thanks for the input Kim, very good info. The aluminum foil was used on my second pour attempt. The wax paper from #1 is still firmly attached to that blank. Most of the foil pealed off the blank with almost no effort. As for the air bubbles, I did end up with some on this pour. I used the down side of the mold as my show side and sanded most of the air bubbles out. Some I filled with thin CA as I sanded down the backside of the guard. The small fills on this dark guard are invisible from the front, but with lighter colors they many be more apparent. Since this blank was for an archtop instrument I wanted a thicker blank than one would need for a flat top guitar. I think the thinner pour would be easer to remove all the air bubbles from. Some of the bigger ones I popped with an old high e string and they settled in just fine. The trick is to find a setting on your heat gun that gets the epoxy thin enough to breath but not so hot that it sets up too fast. On my first attempt I set the mold under a light bulb and wound up with an island of very hard epoxy surrounded by a lake of thin epoxy. That guard basically has a sun spot now. In terms of the heat affecting the cured strenth of the epoxy it may be a good thing for this use as it may help keep the finished guard from becoming too brittle. This stuff has about the flex you would expect from a .090” thick piece of celluloid. Well, here is a shot of the finished product. My only concerns at this point are how this thing is going to hold up. I am hoping that it doesn’t become brittle over time and crack. While I had this sucker on the buffer for a final polish I did catch an edge and the guard hit the concrete floor and survived, so I hope that's good news. Louis ![]() |
Author: | Mario [ Sat Oct 21, 2006 2:59 am ] |
Post subject: | |
Nicely done! You have me thinking... I use Greven's Tortis material for my mandolin pickguards, sticking it onto a piece of scrap guitar top spruce, then binding it with binding I cut from the same sheet of tortis material. It makes a stable, and very lightweigth pickguard, and the light colored spruce adds to the 'guards color and texture. I have also used flamed maple as the backer, giving yet more options for different 'looks'. What I'm thinking you could try with what you've come up with, is to mix the epoxies directly on the spruce or maple backer. Perhaps this would allow a thin layer of epoxy that wouldn't need thickness sanding and wouldn't have a chance of becoming brittle with age. Also eliminates the foil step... All that would be needed would be a level sanding and buffing. Worth a shot if you want to keep messing with this sytem(and I think you should, as this looks really neat). Here's an example of one of my guards. The shot was taken with flash to show the spruce underlay better, though it exaggerates the color a bit. as an added 'bonus', the spruce underlay will darken att eh same rate as the mandolin's top, so the 'guard should retain its color match as everything ages. ![]() |
Author: | jhowell [ Sat Oct 21, 2006 7:08 am ] |
Post subject: | |
Great idea! In a past life I worked for a company that made 'cultured marble' for bathrooms and kitchens. It is nothing more than epoxy resins colored to look like a variety of stone. The resins were molded on steel table tops with steel bar stock of varying length clamped in place. Barstock and table tops were waxed with an automotive wax as a release agent. Any paste wax works -- what ever is on sale. Now to the meat of it regarding air bubbles: The tables had industrial strength vibrators that were turned on for the first ten minutes of so after the resin was placed in the mold. Entrained air bubbles all rose to the surface fairly quickly. The resin was designed to go off in about an hour This could all be mimicked easily and inexpensively for those wishing to do custom pick guards, tail pieces, heel caps, etc. |
Author: | Brock Poling [ Sat Oct 21, 2006 7:46 am ] |
Post subject: | |
It has been a long time since I was in a lab... but aren't there small vibrators ![]() |
Author: | Mario [ Sat Oct 21, 2006 10:45 am ] |
Post subject: | |
A simple vibrator could be readily made at home, using a speaker attached to a heavy cookie tin. Tune in your favorite talk show, and let the big voices do the vibrating. Or, connect the amp to your computer and it as a signal generator... Or a piezo buzzer from Radio Shack, or..... Lots of ways to go about it. Good ideas coming forth! |
Author: | Kim [ Sat Oct 21, 2006 10:59 am ] |
Post subject: | |
Combined these ideas with a hair dryer to thin the mix and you would be done in no time.....and hey Mario, you could have Dylan's "Blow'in in the wind" playing on the stereo or maybe Carole King's "I feel the earth move" or how about "Shak'in all over" errrm...ok I'll shut up now. ![]() Cheers Kim |
Author: | Kim [ Sat Oct 21, 2006 11:10 am ] |
Post subject: | |
And let us not forget the notoriously effective spin cycle on the washing machine. Tape Mario's big speaker on the lid of the machine with the mold on top of that, crank up the Hi-Fi with Pink Floyd's "Welcome to the machine" on full blast, hit the go button on the washer, switch on the hair dryer, and wait for the men in white coats to come and get ya just after the wife goes scream'in from the house. (they can get very protective of that spin cycle you know) ![]() I'm pick'in up good vibrations. She's giv'in me excitations. |
Author: | Serge Poirier [ Sat Oct 21, 2006 3:29 pm ] |
Post subject: | |
Kim, AC/DC's " you shook me all night long" would be more appropriate to get 'em bubbles out, don't cha think? ![]() ![]() ![]() ![]() |
Author: | Serge Poirier [ Sat Oct 21, 2006 3:30 pm ] |
Post subject: | |
Great thread guys, very informative indeed, i'll know what to do now for home made pick guards, Thanks! |
